logo top part Winchester Garden Machinery
Greens Mowers - Ride On
We’ve found honest input from the field to be the most valuable engineering insight possible. So if you wonder what genius first conceived the unique advances detailed on this page, chances are it’s a customer just like you.
No “triplex ring” left behind.
With offset cutting units, the operator can eliminate “triplex ring” just by alternating the direction of the clean-up cut (clockwise or counterclockwise) every day.
Precise cut even on undulating greens.
Using a swivel ball joint, the cutting units float independently of the lift arm. This minimises the chance of scalping, while allowing the units to follow the ground contour closely even during turns.
Easy to set at the correct height-of-cut.
Revolutionary Quick Adjust cutting units allow reels to be adjusted to the perfect cutting height in seconds, with a power drill. So it’s easy to roll out every morning at the desired cutting height.
A level cut when walking.
A forward-mounting pivot point reduces operator infl uence over the cutting plane, so our pedestrian greens mowers produce a more level cut.
John Deere Honda Allett Gambetti Stihl Tycrop Turf MechTrilo Echo
