You told us you wanted straighter tracking in a walk behind greens mower, a more level cut and easier servicing. And that’s what you’ll fi nd in C-Series Walk Behind Greens Mowers. Dual traction rear drums powered by an external differential drive delivers even power distribution for straighter striping. A forward mounted pivot point reduces operator influence over the cutting plane of the mower. Hand adjustment knobs allow for easy, fine adjustment of bedknife-to-reel and a quick adjust handlebar fits operators of all sizes.
The 180C
This narrow 18 in (45.7 cm) walk behind is made for
the undulating greens on your course. A bedknife
for cutting down to 1/8 in (3.2 mm) is standard
equipment. As an option, a 5/64 in (2 mm) ultra
low cut bedknife is available.
The 220C
An excellent all round performer, the 22 in (55 cm)
220C features reduced sound levels, decreased
distance between the safety bail and handlebar for
easier handling and rear drum designed for less
maintenance.
The 260C
If you hand mow tees or want to improve productivity on greens, the 26 in
(66 cm) 260C is the perfect choice. You can choose between a standard 7 blade
or optional 11 blade reel. A larger muffler reduces noise. And the rear roller is
dimpled for better traction.
